'05 OEM headunit replacement question | Ford Explorer Forums
Am_Dew
Somehere in Northern CA
2017 Limited
I'm thinking of replacing the factory headunit in my '05 Explorer XLT...it does not eject CDs on demand and is out of warranty.
It currently has the standard factory AM/FM, single CD system with factory sub, which I presume is driven by a deadacated factory sub amp.
Does anyone know for certain if this system has an external factory amp which drives the four 5x7/6x8 door speakers? Do dealers typically know this sort of information?
If so, replacing the HU is going to involve more work than I anticipated since I will neeed to either run new speaker wires from the HU to the speakers or tap into the existing ones somewhere after the factory amp.
Thanks!
Here is what I found out. I don't know if there is an amp because it says N/A.
Radio 12v white/yellow
Radio Ground black/lt. blue or black/orange
Radio Ignition black/pink
Radio Illumination red/black (dimmer)
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- orange/lt. grn - lt. blue/wht
RF Speaker +/- white/lt. grn - dk. green/org
LR Speaker +/- gray/lt. blue - tan/yellow
RR Speaker +/- orange/red - brown/pink
