you need to look up the axle code on the sticker of the driver door, or there is a tag on the diff cover that has the stock gearing. All trucks came with different gears there is no way we would know what you have without either the dif tag numbers or the axle code.
Once you get the axle code do a search on "axle code" and you will find many write ups on what each axle code means.
