StangsandMavs
- January 30, 2009
- PA
For the 4.0L engine guys...
I did a timing job on our 06 Explorer with a 4.0L a couple years ago... used the complete Cloyes kit... only put about 5k miles on it and the wife came home with a loud tap that sounded like a chain, again.
I tore the top of the engine off... ran a scope down the rear cassette and checked out the front cassette... everything was in tact.
I cranked the engine with it open and observed that while there was a lot of movement on the leaf spring tensioner... I didn't have anything to compare it too, just seemed like a lot... it also seemed in tact.
I did find a lot of broken insulation on wires... including the knock sensor, cam sensor, and bank 2 fuel injectors... maybe something was getting crossed?
The tensioners were all new with the kit, but I had another set of new (hydraulic) tensioners that I threw in, just in case. I addressed all the wiring and cinched it back up. I didn't have an extra leaf spring tensioner. I added some Marvel's Mystery Oil in case it was a matter of something sticking... within about 30 miles of driving, the noise quieted down substantially.
Fast forward a week, and she comes home with the engine tapping again.
I take it for a test drive the next morning... about 8 miles into the drive, the CEL comes on. At the next stop sign, I had to take a right, but it was busy 55MPH, so I had to get on it. It revved up to about 4500 RPMs and I pulled on a quick exit/shortcut to the house... the engine just completely shut off like someone flipped a switch. No noise. In total, it was probably 3/4 of a mile between the place where the CEL came on and the place the engine stopped... with that 4500 RPM rev in between.
I came to a stop and tried cranking it... no noise, but it cranked fast.
Had it towed home.
The CEL was for a camshaft position sensor.
Did a compression test, and nothing in multiple cylinders on both sides... so I figured it was something with the center Crank to Jackshaft chain.
Pulled it back apart, today... cassettes are still in tact, but the crank to jackshaft chain broke... and is laying balled up on the bank 2 side of the engine. The only thing other broken is a piece of the black plastic guide, from the side that doesn't touch the chain. that might have broke while I was cranking it.
Upon a further look, the nylon piece on the leaf spring that rubs against the mount has been worn. This would have had the effect of lessening the tension
Obviously, something was bothering this timing set before the chain flung off. Maybe the tensioner, the chain, or even the sprockets themselves... maybe it was the mechanic's (me) fault... but any suggestions would be appreciated.
Thanks, guys.
Had it towed home.
Thanks, guys.
