admsbmr
- October 20, 2010
- SLC, UT
- 2007 Explorer Limited V8
I have posted this in the 06 to 10 stock section and it was sugested that you fine folks here in the towing section can be of more service.
http://www.explorerforum.com/forums/showthread.php?t=378615
on my 06 explorer with the class III factory setup I am only getting power at the plug for trailer brakes, hot lead to charge the battery and reverse lights. I however am not getting stop, left, right or running light (you know the important stuff) on either the 7 round or the 4 flat. I have checked all fuses under the dash none blown and getting power as confirmed with my tesdt light, I have checked all fuses and relays under the hood and none are blown and all have power again checked with my test light. I have hunted around the rear bumper and found that all connections seem secure and corrosion free, are there plugs on the passenger side interior compartment that may not have been plugged in? if so that may be my next thing is to take out that trim pannal and look to see if something has come undone or has not been comnected from the factory. again thank for the help and I hope to have this solved by the weekend so I can help my sister move.
