07 Eddie Bauer Electrical Nightmare | Ford Explorer Forums
xraydude
Cape Cod, Ma.
2014 Explorer Sport :-D
Hello everyone, my 07 is acting up. It started missfiring about three weeks ago once a day for about a minute then run fine for a few days and start acting up again. Had it scanned, no codes:(. Today my trac-control light started flashing while on the highway and no matter how far down I put the pedal I could not accelerate. Then like that it started running fine. A few miles later it started doing the same thing but this time the ABS light came on @ the same time along with the "Drivetrain Malfunction" indicator. Once the ABS and Trac-Control lights stayed on steady, she ran fine. Another thing I noticed was when I shut off the engine, remove the keys from the ignition, and open the drivers door, none of the other doors would unlock like they normally would. Any advice would be greatly appreciated.
XRAY: Check the wiring harness where it clips to the ECU under the hood. There was a tech bulletin that said the harness is prone to chaffing underneath where it sits and rubs on other components. If yours chaffed down to the wires you can be shorting the signals causing all kinds of problems.>>>AJ
read my post about warning lights
