yousef_d94
- September 23, 2020
- Muscat, Oman
- 2007, Explorer, AdvTrac
Hello everyone,
It all started when my brake booster failed, the traction light appeared on my dash and after I changed the booster the light was still on. That was last year, and I was told then that the master cylinder had a small leak and needed to be replaced soon. Fast forward till now, I got warning on the dash that brake fluid is low. I made a full service for my braking system. I changed the master cylinder, I flushed the system, air bleed, new brake fluid, cleaning brake calipers, and put new brake pads. I had also a problem with the parking brake light, it kept on even when I release it, I had to change the parking brake switch and it fixed the issue. However, the traction is still on, this affects the drive massively, the car feels like it's braking on it's own. I checked online and found out that it could possibly be ABS sensors and wheel speed sensors. After checking those they seemed to be alright.
Does anyone has an idea on how I can tackle this issue? I would appreciate your help.
Thanks!
Thanks!
