07 transmission problem | Ford Explorer Forums
Chris Schroeder
LaPlata
2007 Ford Explorer
The situation that I am having with my 07 explorer is in the transmission. The trans will run through all gears while in drive, if I put the trans in neutral or reverse it will not ingage in neither, the trans will stay in the drive gear although it will not move when you press the gas pedal.
I have replaced the fluid and filter and that has not helped l, I am thinking it might be the solenoids??Any help with this would be appreciated.
Thanks,
Chris
