abakedapplepie
- September 11, 2010
- Detroit, MI
- 2002 Sport 2dr
Hello all, hoping someone can shed some light on this issue.
I bought the vehicle from a ford dealership a few months ago, everything has been fine until about 5 days ago I was coming home from work and the RSC service now warning came on. I pulled over, turned off the vehicle, and started it back up - RSC warning gone, everything fine.
Fast forward to yesterday - I am pulling out of my house, and the RSC Warning Alarm comes on again. This time, my gauges all die except fuel level, and it says low fuel as well as RSC Service now. Most of the dash lights are on. Wrench, brake, engine, TC, and a few other lights all on. I shut the vehicle off and go to start it like I did earlier this week and the truck won't start. This is about the time I started panicking. Pushed the truck back into its parking spot and hit the internet.
I found plenty of resources for the RSC Service Now issue, but it seems that is not my problem here. For one, all the other discussions I had seen showed that only the TC light was on and the RSC alarm was going off. The gauges still worked and the car still drove.
I unplugged my battery and let it sit hoping it would temporarily clear out whatever was going on so I could at least move the car into a better spot. It worked, and it continued working for the rest of the night and got me to and from work today. Until now.
I just pulled in from work, and the same thing happened. When the alarm started going off while I was driving, I noticed my temperature, RPM, and speedo were all off. This time I paid attention to the theft light and sure enough it was blinking rapidly, so I went to grab my spare key. Same thing.
What happens is I go turn the ignition and the gauges reset, the fuel says its low even though the gauge shows 1/4 tank. All the aforementioned lights turn on. The RPM gauge goes up to 2k and then drops to 0, and the car doesn't start. The coolant gauge doesn't move.
My question is, why is the RSC Service Now alarm going off when it very clearly isnt what the problem is, since that alarm does not cause the car to not start. The engine light is on currently, but otherwise when its driving normally its off. I assume there is some odd code present that is causing the car to not start but I just dont know and I dont have a reader to find out. What could be happening here? I would imagine the key chip reader isnt at fault if removing the battery and resetting everything suddenly allows it to run normally, right? A fault in the ignition security would prevent it from starting regardless of the state of the computer (or at least I would hope so)
I'm really afraid that there is something wrong with my ECU. If someone could point me in the right direction troubleshooting this it would really make my day go a little better.
