1/2 or 3/4 ton coil springs in my '92 2wd? | Ford Explorer Forums
mercerd92
Charleston, SC
'92 XLT
Need help! 1/2 or 3/4 ton coil springs in my '92 2wd?
Hello! I am trying to get 4 to 5 inches of suspension lift on my X pretty cheap. I already have a 2" BL. Out back I plan on doing a spring over axle swap using mountain offroad mounts. Up front I want to match the rear height but not sure which springs would give me the desired height, 1/2 ton or 3/4? I have the radius drop and axle pivot brackets and dropped pitman arm to go up front. I am also planning on getting the extended brake lines from JamesDuff.com. Does this sound like a good idea to anyone? If These springs won't work, can anyone give me a suggestion as to what would and where to find them? Thanks Alot!!! :thumbsup:
Dustin Mercer(USAF)
