Afboy143
- September 23, 2003
- Tampa,FL
- 1999 Ford Explorer Sport
Hey guys,
So the Exploder hit 125k miles today which I feel is a pretty big mile stone. There are two small projects I feel like I want to undergo to make sure things last as long as possible!
1) Transmission
-Current preventative measures: Secondary B&M Transmission cooler (as well as the stock one and the stock towing package one)
-Purafilter oil filter allowing me to use a oil filter to filter the transmission fluid. Filter changed every 3k with oil changes and a quart of fresh transmission fluid added
I plan on changing the filter (never done, yikes) and getting the tranny flushed (done at 75k)
2. Engine
-Synthetic Mobil 1 always used during oil changes.
I plan on running two bottles of the grey bottle of Gunk. The stuff you pour in the oil, run the motor for 5 mins in idle while the stuff cleans the crap out, then you change your oil to get it all out. The reason I say run 2 is the bottle says a second application might be needed for older motors. Since the lower oil pan gasket is leaking slighty, I can run two bottles (it says if two ran, drop the oil pan and clean real good).
Goes anyone think this is a good plan? Since the engine is older, is it okay to flush it like it without harming any aged sealed? Let me know. Thanks
1) Transmission
2. Engine
