Jc1985
- November 5, 2020
- Longview, Texas
- 17 Ford Explorer Limited
Good morning. Hope I’m in the right place if not please point me the right direction.
I’ve searched the forums and most of the issues that come close to mine generally involved not just controls, but air in the rear as well.
The rear controls on the back of the center console have no power....no lights, can’t control heated rear seats or climate. However; the ac and heat are still functional and can be controlled from the front. The problem is only with the rear controls. Everything was working fine and it seemed the loss in power to the controls happened around the time my daughter had been using the heated seats in the back.
I’ve even taken measures to verify I’ve done everything I can before posting. I’ve checked the fuses that could’ve been a potential problem and verified that my front controls where set properly, still no luck.
If you have any insight or recommendations to remedy this problem I would be extremely grateful.
Thanks
Thanks
