17" Explorer Xpress Wheel Questions | Ford Explorer Forums
hornz2000
Athens, GA
1998 Sport
I am looking into buying 17" wheels for my 98 X Sport. Xplorer Xpress has 17x7 wheels with a 15mm offset. My question is what is the widest tire I can fit on that, a 265 possibly or less? Also, what does the offset mean to me, will it stick out past the fender a little or what. I am also looking at a 17x8 wheel with 0mm offset. I have the same type questions on those, Thanks.
ok, offset is the distance from the center of the wheel (i.e.: if the wheel is 8" wide, the center of the wheel is 4" in from either side) to the mounting surface (i.e.: the surface where the wheel contacts the truck hub.)
the smaller the offset, the more the wheel will stick out from where the stock wheel is (there can also be negative offest which means theyre gonna stick out more.) i dont know what the stock offset is on our wheels, so i cant really tell you how far theyll stick out, but keep in mind that when you go with wider wheels, such as 8" wheels, the offest is gonna change, but that doesnt mean that theyll stick out, its just to make up for the extra width.
im also in the process of getting some 17x8 wheels, and i jsut called my wheel guy to let him know which ones i want, and hes gonna call me back with the specs of the wheel. i hope this helps a little bit - you might also wanna try giving EE a call - i dont think they sell anything that wont fit an explorer.
Hornz, just call Explorer Express, they're really helpful and should be able to help you with the biggest trie size.
I just ordered my Cobra R's and should have 'em soon!
