96AWD5.LOL
- March 14, 2012
- Location
- Austin, TX
- Austin, TX
- 91 XLT 4x4 - "Red Velvet"
Hello All,
Despite my username from years ago I now own a 91 ford explorer 4x4. I have done quite a bit to it to bring it back to life as the previous owner didn't do to much quality work to it in the 6 months he had it. Below is the list of items completed within the past month to bring the truck back to life (read---> safety):
1. Transmission fluid change – Done
2. Oil change – Done
3. Brake fluid bleed/flush – Done
4. Alignment – RMS – Done – Recheck --> Suspension/Tires? sag causing wheel to drift right?
4-a. Check tire pressure first -6/19 --->changed all to 30 PSI
4-b. Rotate tires.
5. Tie-rod Ends - L and R - Done
6. Check brakes on front for even wear Done
7. Check front end components Done
8. Replace shocks Front and Rear - Done
9. Replace plugs and wires Done
10. Clean up underneath power steering fluid and oil from bell housing – Done
11. Check E-Brake and Rear Brakes – ME – E-brake working well. Rear brakes may be in good condition. Check adjuster?
12. Clean IAC - Done
13. Fix Upper Radiator Hose - Done
14. Rotors X2 – Done
15. Pads X2 - Done
16. Bearings (timken) x4 – Done
17. Bearing Seals (timken)- Done
18. Guide Pins – Done
19. New Calipers x2 – Done
20. Replace high pressure power steering line – Done
21. Flush Brake lines (Front) (second time) – Done
22. New radius arm bushings (moog with heat shield) x2 – Done
23. New trans cooler (added two Hayden's) x2 – Done
24. New fan – Done
25. New heavy duty Fan Clutch (Hayden) – Done
26. Take off throttle body and clean (sticking) - To do...
26. New steering gearbox.
27. New front rubber brake lines.
My front two tires aren't in the best condition but at 30 PSI each the truck drives straight now. When braking there is a gradual pull to the right - Non-violent. When bought, the alignment was off and both calipers were bad. Before realizing both calipers were bad I replaced the front rotors and pads along with wheel bearings. I used high temp brake grease on the guides and touching surfaces, cleaned the rotor with brake cleaner and reassembled. After a few miles I realized the right caliper was sticking under heavy braking (only stuck once on a 5 mile drive) and the left wouldn't engage until hard pressure was applied. They were replaced immediately. Rear brakes haven't been touched yet but as shown above the e-brake works well. the right hand pull has existed since I purchased the truck initially but was way more violent before new bearings, calipers, pads, rotors, and RA bushings.
Its been suggested to me to look into Axle Pivot bushings. Although old, they don't move much with a pry-bar. I am going to swap the tires from left to right up front to see if it changes the direction of pull tonight. So while i'm out with my tools does anyone have any other suggestions?
4-b. Rotate tires.
15. Pads X2 - Done
24. New fan – Done
