Anime, thanks for the tip on the variable orfice tube. I need to rebuild my '94 A/C system, which has R134a of course. Would using the variable orfice tube be of any value?
The 1994 R-134a system is, in reality, a factory-retrofitted R-12 system, with the additional benefit of a pressure sensor in the main hose line (at the filter), due to the higher pressures of R-134a over R-12.
I would guess that the variable orifice valve would improve the cooling ability of the system due to this, but plenty of sites for the VOV also tout them as an improvement for factory R-134a system in more recent vehicles, so if that's true, I don't see any reason not to use it on the Explorer.
The only thing I would caution you is to be sure and get the 'standard' variable orifice valve, and not the (more expensive) 'severe duty' orifice valve. The severe duty version is for use in climates that regularly see temps over 105+ degrees or so, and it seems to be pretty restrictive or at least presents the very weird risk of the orifice valve being pushed out of place and into the receiver/drier due to system pressure.
Maniak had this happen on his rig with a bang when the valve broke loose inside the tube and had to crush the orifice tube on the receiver/drier to hold the new tube in place.
I should also suggest you use Nylog on the green o-rings to seal up the system when rebuilding it. Seems to be worth it for the minor expense. Be sure to get the "HFC" kind with the blue lettering for use with R-134a, the red lettering HFC-HCFC version is for use with R-12 and R-22 systems.
Also suggest you get genuine DuPont R-134a cans if going the DIY route when refilling, not cheaper stuff, especially anything with leak sealant or dye. I've found it at some auto parts stores, and it isn't any more expensive than the R-134a anywhere else, or if it is, they will usually match the price of the parts stores around them. The other brand name R-134a with no sealants or dyes is ok, just hard to find since the major parts stores generally carry gimmicky stuff, guess it sells better.
