1993 Explorer Stereo install help! | Ford Explorer Forums
Isaacm1986
Stanwood WA
1992 XLT
I have spent the last two hours browsing the site and cannot for the life of me find the answer!
I have a 1993 ford explorer XLT, with the premium sound from ford, I bought a new ingsignia cd deck today, cause my stock stereo has never worked since i bought it. I pulled the stock stereo out, and low and behold all the wires have been cut! someone cut the stock harness! so i went online here and found a wiring diagram, I cannot get the cd player to turn on at all, let alone play any audio! I have checked all the fuses, and they are fine, is there something i am missing? how can i get this to work? any info is helpful!
Make sure your getting 12 volts between the yellow and black wire(key on). I'd start there and report back.
Check the red one with the black wire while your at it.
just checked the yellow and black wire, and it is reading a big zero!
Well thats one of your power wires lol... Check your fuses again or try grounding on a different wire. A seat belt bolt should ground
just checked it again, 12 volts, just did not have a good ground.
Should at least turn on with 12 to the yellow and red with a good ground. Check all your wires. Make sure you push the power button on the deck to lol
now there is no red wire out there, yellow and black, there is a black, then a black and green, and then a yellow and green, but no red?
Let me check a diagram 1 sec. There should be a red and yellow on the deck side for sure. 1 is 12volt constant and the other is Ignition
i got it powered, the yellow and green wire is the constant power, anyway it powers on at least. I will try to figure out speakers tomorrow. any tips on that?
Match that with your deck wiring. The deck wires should be labeled
Factory 8 Input Gray/Black Plug
This plug only had six wires in place
Yellow/Green - Memory Power (const. 12V+)
Yellow/Black - Ignition (Switched 12V+)
Black - Ground Wire
Blue - Amplifier Remote
Blue/Red - Illumination
Glad it worked,
Heres the speakers
Secondary Plug
Left Front (+) - Green
Left Front (-) - Orange/White
Right Front (+) - Red/White
Right Front (-) - Brown
Left Rear (+) - Light Blue/Black
Left Rear (-) - Yellow
Right Rear (+) - White/Purple
Right Rear (-) - Light Blue
thanks, i will check back tomorrow and let you know how it all goes!
