puttputt
- February 8, 2013
- PNW
- 1994 XT 3.0 5spd
After purchasing this '94 three weeks ago, I've detailed a preliminary list of to-do's & modifications. First & foremost was a persistent oil leak which appeared to be the front crank seal - well. I was wrong. After drilling down to the suspected culprit, I found instead a misplaced (pushed out) pan gasket seal along the bottom edge of the timing cover. Fortunately, the gasket wasn't damaged. After seeing this, I 'd be wise to add a PVC valve replacement to the to-do list - then double check for crankcase pressure... eh?
Since it was necessary to pull the timing cover, I thought I'd go ahead and renew the timing gears & chain. They definitely needed replacing as there was more than an inch of lateral slack causing the valve timing to be about 7 degrees retarded - NOT good for MPG.
Reassembly will see a few changes. First is the elimination of the OEM fan and all A/C components, and the installation of an electric fan (heisted from dad's '97 Taurus).
After buttoning the engine back up, I'll probably focus on exhaust system modifications, then tackle the electrical quirks.
And after the flowers start blooming, I plan to replace all rear side glass with fiberglass panels - I always preferred a true cargo van, but could never locate a decent one w/5spd.
Here's the victim...
