Yankee516
- May 28, 2010
- Long Island, NY
- 94 XLT, 99 5.0L AWD
Morning all! Sorry, but I accidentally posted this in the new members forum, don't know how to delete that thread...
It is Memorial Day Weekend and I am about to undertake my first A4LD service with the inspiration of so many of you. First off, thank you ALL for so many postings that detail how to rehabilitate these miraculous devices! I can't tell you how many hours of research I have done thru your postings!
We have a 1994 Explorer that runs great... except for all forward gears now. Our journey began about three weeks ago when the transmission started sticking in first gear when cold, but otherwise functioned great with some slipping. Obviously a sign of a sticking governor in retrospect and overly thick fluid. Due for service and an inspection, the shop recommended a pan drop, filter replacement and replenishment of fluid at 160k (no power flush). We thought that was a good idea since the truck is old and the shifting had gone downhill.
After the service everything was fine, drove the truck for over 200 miles and it shifted great! Next day, only reverse...no forward gears. After some coaxing (slightly higher RPM) it did go into drive intermittently. This could not be replicated very often. I disconnected the vacuum modulator and plugged the tree at the engine block to try higher pressures. With the VM connected, I never had any success getting forward gears but reverse worked without a hitch! This worked for forward once in a while and the car drove great once it was in drive, but once I went out of any forward gear with the engine/tranny warm no dice. After checking the fluid level, I figured that the seals might not be holding pressure. I siphoned some fluid out thru the fill tube and it was black and thick. I then added some Trans-X as recommended by some members. Unfortunately I was never able to get the truck back into drive for a trip to work it through.
Now that I can't achieve any forward drive gears (only reverse which has AMPLE pressure and engaging with a BOOM without the vacuum modulator connected), I decided to spend Saturday of Memorial Day Weekend to rebuild the valve body in the hopes of getting the truck to drive. I bought the Transgo kit and Sonnex valve upgrades to attempt to remedy the situation temporarily. I am pretty sure that the brown fluid is pointing at a rebuild of the clutches and bands, but I can't understand how it could have gone downhill so fast! I just want to get it into drive.
Any suggestions would be appreciated!
Cheers!
--Phil
Cheers!
--Phil
