1994 Dash Temp Gauge | Ford Explorer Forums
DasBaldDog
Greensburg, PA
1994 XLT 4.0
Quick question, I replaced the ECT in the engine recently when I did the LIM.
However, upon startups in the morning, the needle on the temp gauge takes 10+ minutes of idle to reach anywhere near the middle of the gauge, but the heater core hoses are hot long before, cab reach temps where I can't touch them for more than a second or two.
This gauge isn't controlled by the ECT sensor, is it?
There's a little gauge sensor with 1 wire going to it next to the thermostat.
Nope. . ECT is the 2 wire temp sensor in the lower intake. The gauge is run by the 1 wire temp sensor in the lower intake.
~Mark
So if this gauge reads a little slow, not that big a deal, right?
In most cases. But you may see a mileage drop & you may not know if your overheating if it happens
Well, I believe it's working as when driving, the needle gets to abd stays around the "R" in NORMAL. it just takes a while to get moving.
I don't know what the gauge range is. If it's 180-210 then I'd say it's fine as it would take a few minutes for the engine coolant to warm to that level, but if the gauge range is 100-250, then something is wrong as it should take about 30 seconds to warm to 100 as hot as it's been here.
When I leave work I will try abd time how long it takes to get into the "normal" zone.
Apples to oranges but my mazda3 gets to operating temp inside of 2 minutes at idle.
Your thermostat may be stuck open so it takes longer to get up to operating temp.
Not that this guarantees anything but the thermostat is brand new.
