1994 Explorer prerunner? | Ford Explorer Forums
pilotmike
Yucaipa, CA
'94 XLT
i have a 94 explorer xlt stock...i want to lift it and kinda build it into a prerunner...preferably coil overs and enough lift for 33's...any suggestions?
If you want to build it into a prerunner for looks I would not suggest coilovers honestly. It is not the best option to run coilovers off the stock cast beam anyway. What is your budget because it has a lot to do with which direction you take this? New coilovers with spings and hardware are around 1200 for a pair. You can run a bent beam kit with modified radius arms in combo with a lift coil and decent shock and get pretty good performance out of it. Hop on camburg.com or hnmmotorsports.com or autofab.com and check out the options they have available.
I would sell yours and buy Dannyboys explorer. No way you can build yours for what he is asking.
who is dannyboy and where can i see his truck?
