Tedybear
- March 7, 2016
- Fulton, NY
- 1995 Ford Explorer
Well my day went from good-bad-worse.
Did the basic maintenance. Oil change to a motorcraft filter, and went with 10w30 oil. (The P/O mentioned he only used 5w30 and this truck has well over 200k on it. So it's warm enough, let's go with 10w30....)
Had it running for about 20 seconds before shutting down to recheck level. No issues.
Did the cooling service--New thermostat and purged out the air. (This thing had pure 100% coolant that drained out)
Okay. Did the purge, no leaks. Then I noted a very pronounced engine noise starting to surface the longer it runs. Oil pressure gauge of course is a dummy gauge, but it's not reading "0", so it has at least 7lbs.
https://youtu.be/UTfto1dtgQk
That's a link to my video I did of the noise from under the SUV.
I'm still pricing out the rest of the stuff it needs. 4 tires and brakes all around. Yeah I expected brake's and tires. This engine noise? Really not what I'm used to or expecting....
Ideas welcome. This isn't going on the road anytime soon, so there's not a huge rush.
S-
S-
