1995 X lift question | Ford Explorer Forums
Rolla91
Marshall,MO
'00 Eddie Bauer AWD V8
i have a 1995 X 4x4 and i am planning on buying a 3" body lift for it. with only that body lift would i be able to fit 33x12.5 with little amounts of rubbing? if not, what is the largest tire that would fit or what would i have to do to make the 33x12.5s fit? thank you all for any help that you can give. :)
add a good 2" torsion twist and shackles or add-a-leaves in the back and u should be good to go with only minimal trimming if any. there is a tire fitment thread on here that'll answer your question on what'll fit with what lift. look for it.
also depends do you have steps . i have steps and 33's and if i removed the steps. never happen but i ould put 35's under them.
i have the factory running boards and factory fender flares. i found the refrence chart for lifts and tire sizes and i think i should be able to fit 33x12.5s with maybe a small torsion twist(1 inch) and a 2 inch lift shackle with the 3" body lift.
i have factory running boards. and 33's but also at least 3 1/2 inches of TT. 3 inch spindal lift. 2 inch body lift. and 4 total add aleafs in rear plus shackels....
I am looking to go with either 32's or 33's I will have to see what kinda body lift I will need. I am hoping going with 32s I wouldn't have to do too much if at all of a body lift.
Tim
were did you get your spindal lift from?
