1997 4.0L Aerostar. IAC question. | Ford Explorer Forums
rmerrell
white rock bc
97 aerostar AWD
Hello all, I have 2 Aerostars AWD 93 and 97 4.0L. Search engine recommended your site cause of the interchange-ability ( sp) of the parts with Explorers. My IAC needs to be replaced, and I wqnt to use the one off the 93 due to the high price in canada. The only diff I can see is the electrical fitting so I was going to simply solder the pigtail that came off the 93 on to the 97 harness. Will, or might it work , or should I not do it? Rick
Welcome to this forum! I've renamed your thread, and moved it into the Aerostar section. I would recommend only using the correct part. Did you clean the IAC? What's the price difference on both IAC parts?
