kingyoshi2424
- February 9, 2014
- 1997 ford explorer xlt
hello. i have a problem with my shifter in my 1997 ford explorer. it is stuck in gear neutral right now and the key is stuck in the ignition. the shifter lever is loose but its still connected to the column. Ive done some research and it seems to be the linkage or gear cable or are they the same thing. i heard since its a old ford its just a metal linkage. today i shifted it out of park and something sounded like it snapped off. it wont shift back up into park. i also heard it could be a plastic clip or a rubber oring or something like that. please help. does o reillys sell the parts. i think it sounds like the linkage broke. or the gear cable. what do you think. the gears even before it broke today were not lined up properly and sometimes the car would not go into park at all so it would roll backwards when u turned the car off. How do I take off the panel so I can see the steering column? how hard is this to fix in a day? please post link to any diagrams u might know of. thanks
