ragtowne
- January 22, 2011
- Whitefish, Montana
- 2018,Explorer,Sport
I have a completely stock 1999 Ford Eddie Bauer 4WD 4.0 OHC V6 with 160,000 miles. Recently the engine has been stalling when the vehicle is coming to a stop. It does not stall every time but often enough that it is dangerous to drive. It does not throw any codes. No engine check light comes on. After stalling, the engine starts right back up. The vehicle has been regularly serviced.
It has been in the local Ford dealer's shop for over 130 days. They replaced the IAC, cleaned the entire intake system, cleaned the fuel injection system, checked for vacuum leaks, done all of the checks their factory scanners and other tools will allow them to do, and talked with "Ford Senior Technicians". The dealer claims they can get the engine to stall when shifting from reverse to drive with the foot on the brake.
I thought it might be the power brake booster leaking air. I asked them if that could be the cause. They said "no, they checked it".
They now claim it is "most probably" a bad torque converter that is locking up when it should not. They state there is no guarantee that replacing the torque converter will fix the problem. If I decide to pay to have them replace the torque converter and it does not fix the problem, that's just the way it goes - no guarantee.
Does this sound reasonable that a Ford dealership can take over 130 days and only be able to "guess" at what is causing this problem? Or should I take it to another Ford dealer, or to an independent repair shop?
Any help or suggestions would be most appreciated.
