Mikiemic
- August 6, 2012
- Lancaster, PA
- 1999 Ford Explorer
Hi folks,
I need some help! I have a 1999 Ford Explorer with a 5R55E Transmission. It was given to me as payment for a contract that was owed to me. I started driving it and realized it was stuck in 4WD Low. Upon further testing, I went ahead and changed out the Transfer Case Motor, which fixed the problem. A day later I was driving and the vehicle would not shift higher then 4th gear (it has 5 gears, 5th being Overdrive). The overdrive light was flashing. I took it to a transmission shop and to a Ford Dealer to have it looked at and they claimed that it was not throwing any codes, but that there was an issue and that I should replace that transmission. I did some more research and found that it could all be the Valve body Gaskets. Being that I have my own lift, I went ahead and took on the job of replacing the gaskets. They were blown. Top gasket was totally blown out right above the EPC solenoid. I put it all back together and filled it with the proper ATF fluid only to find that it was still not going into the Over Drive gear. More research and I found out that the TCC solenoid could be the issue. Went ahead and replace that. Still not shifting into overdrive gear. More research and found that the EPC solenoid might be the issue. Dropped the pan again and replace the EPC solenoid. That was this morning and now I am at wits end! The problem is still the same! I drove it to a friend that owns his own shop and he ran hooked it to a computer and it still does not throw any transmission codes. I was told that if the O/D OFF light was flashing that it should give me codes but it doesn't. I am open to suggestions! Is anyone else having or has had this problem? Any and all advice is well received.
