- December 31, 2001
- Oakland County, MI
- 97 Mountaineer
I'm posting for a friend - he replaced the clutch (using a kit - plate/disc/bearing - complete) on a 99 2wd ford ranger (using aftermarket clutch) all went well, about 1 month later the vehicle is hard to shift into initial gear, the clutch pedal relases very quickly and has to go all the way to the floor to get into other gears - Are there any adjustments that can be made the the clutch or pedal??? Has anyone else run into this problem and might have some advice. A buddy of mine has a simular 99 ranger replaced clutch on his different aftermarket part and is having a simular issue and both already tried to bleed the system a few times with no imporvments.
Thanx
T
Thanx
T
