codipegrum
- December 2, 2002
- Savannah, GA
- 1999 XLT
Hello everyone,
I have a 1999 XLT with a V6, SOHC, which has all original factory equipment including a Returnless Fuel System (!!). It appears to be a Mechanical Returnless Fuel System as there is not an electrical pressure tranducer apparent at the rails and there is a mechanical damper on the rear end of the left rail. There is not however a short return from the fuel filter back to the tank, so I assume this is all internal to the tank along with the pump, a check valve and some form of regulator.
Here's my problem: No information was released by Ford to OEM's of Manuals (Chiltons, etc) and I can find no other information source, which makes troubleshooting a tad harder.
On my engine the fuel pressure, both static and dynamic, is 65 psi and pulses during the dynamic condition very rapidly approx 5 psi either sise of this datum. Additionally, upon engine shutdown, pressure returns to zero after approx 5-10 minutes (installed an isolation valve and determined pressure is returning to the tank and not leaking through bad injector/s).
Does anyone know whether the fuel system conditions above are bullsquat? Does anyone know if the check valve (if existent as assumed) goes bad, regulation can be negated?? Does anyone have any information available for this particular type of fuel system?
Yes, slow starting and rough idle issues. Suspecting above after exhaustive troubleshooting, throwing (some) cash at other possibilities and thwarting attempts by local clueless stealaship to swallow all cash reserves in one gulp!!
Thank you all for any and all feedback available.
Kind regards,
Colin
Kind regards,
Colin
