sethdromgoole
- November 27, 2010
- Park City, UT
- '91 Eddie Bauer
Replaced my auto hubs with Warn manual hubs in the fall. Worked great all winter with no issues. About a month ago I had my summer tires put on, and noticed pulling to the right. About to weeks after that I a sound started from the front right tire when traveling at high speed -- the sound goes away when making sweeping left turns and gets worst when making sweeping right turns.
I pulled the wheel apart to discover the warn hub had seized. The retailer replaced the hub under warranty, and I chalked the issue up to having broken the hub; however, after about 30 miles of driving the next day the new hub seized too. Obviously the hub is a symptom of some other problem, but not sure what.
I pulled out the bearing and this is ok. The only issue I see is that with bearing removed I am unable to move the spindle -- it turns only. On the working side, when I remove the bearing I can move the spindle a few mm in each direction.
Any ideas?
Any ideas?
