fordtrucknut
- September 18, 2012
- Utah
- 2000 Ford Explorer
My parents 2000 Explorer is having issues...want to see if anyone has had the same issues....It started with check engine light...came back to Oxygen sensors...Replaced all 4....light came back...still a couple of same codes...P1151 and P0153...smoked the intake with Evap Leak Detector...have several small vacuum leaks...little at EGR (No EGR codes)...little at TPS (No TPS Codes)...Little at throttle shafts...and some coming from what looks like underneath throttle body....none of these are as much of a concern as the next thing....NOW the trans will not shift out of 1st...unless you manually shift it from Drive to 2nd...then no other gears...Reverse works fine....No Slipping at all...Serviced Trans as well and nothing out of the ordinary in pan...picking EVERYONES brain...if I have forgot to mention anything about symptoms etc...if you spur my brain by a comment...i will let you know if I have tried it....This is their only vehicle and I need to get it back on the road for them ASAP...they are in their 70's and need it to get to Doctors quite a bit. Thanks in Advance!!!
