2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
defective fuel pressure damper
Thanks for reminding me about his problem and the solution. There is a diaphragm in the damper just like the one in the pre 1999 rail mounted fuel pressure regulator. If the diaphragm leaks then fuel will be sucked into the vacuum line. However, the symptoms in this case don't match well with that as the source of the problem. Vacuum is max at idle and min at WOT. Therefore (in theory) the fuel pressure would be least at idle and max at WOT.
99sportx has a thread for an issue similar to this one, and the culprit was indeed the fuel pressure dampner on the 99 up fuel rail. Just a heads up.
