Delonybro
- May 11, 2008
- Abilene, TX
- 2000 XLS 2WD
Driving tonight with High Beams on, all of a sudden the Headlights stop working. No Hi Beams, no driving lamps, no fog lamps. The Hi Beam indicator is on, however, no matter how I move the switch or pull back as if to flash the Hi's, nothing will turn the indicator off or turn on my lights. Limped home about 30 miles on the auxiliary fogs
. So far I have:
Checked all fuses/relays
Turned the main headlight switch on/off several times
Disconnected/Reconnected battery
Any other ideas? About 2 months ago my multifunction switch burnt up and caused my brake lights to stop working so I replaced the switch. Maybe the new switch is bad/something burned it up again?? Any ideas would be helpful. Thanks!
