doctordeeptrack
- May 20, 2015
- Dallas, TX
- 2001 Ford Ranger 4.0L V6
How do you get a wrench on those down pipe nuts that connect the cat to the cast iron passenger side manifold. The cat is so fat and the firewall is so close that no deepwell with a universal will fit. an extension with a u-joint has no room. i finally removed the passenger manifold from the motor and pulled the engine and left it in the bay connected to the exhaust system. i was able to pull the motor with the driver manifold on the block. the nuts were so frozen i had to cut them off and put new studs on the passenger cast manifold flange. i still have to put the flange nuts back on when i stab the motor but don't see how.
