2001 sport trac 4.0 intake man. torque specs | Ford Explorer Forums
01sporttrac
washington
2001 explorer sporttrac
i need the torque specs for the intake manifold and everything else i would need. what we are doing is replacing the timing chain tensioner. thanks jdmg2gsr@yahoo.com
The EGR tube nut is 35 Nm (25 lb-ft) the bolts that hold the coil pack bracket to the intake are 8 Nm (71 lb-in) and the coil pack bracket bolt that goes to the side of the head is 23 Nm (17 lb-ft) and the bolts that hold the intake on are 10 Nm (89 lb-in) the t-stat housing bolts are 10 Nm (89 lb-in) and the tensioner is 44 Nm (32 lb-ft) This is for the left hand side for the right hand side all you need to do is remove the wheel and splash gaurd and you can easily get it through the wheel well
Nate
No problem :thumbsup: Its too bad because the tensioners were under warranty their was a TSB on them from ford but any that vehices that were covered are out of coverage now Too bad.
Nate
