2002 ABS - hoping to find some help | Ford Explorer Forums
catherine
Greenwood Lake, NY
2002 Explorer XLT
Hello all. I have a 2002 Ford Explorer XLT. I need to know if it has knuckle or differential mounted sensors and if the stud and toe link is 15mm or 17mm. I believe the production date is February 2002. Not 100% sure. Been searching all over the web without any luck. Could use some help. Thank you!!!
Been doing a little bit more research. 15mm ABS sensors are mounted to the knuckle and 17mm ABS sensors are mounted to the rear differential. The size of the stud and toe link for the rear is either 15mm or 17mm. All of these sizes are based on the production date. March 3, 2002 or before is 15mm and March 4, 2002 and after is 17mm. Just need to find the date on my truck. So nice that Ford made this so easy. I'm not that surprised considering everything that has gone wrong with this truck (2002 Ford Explorer XLT). The list goes on and on. I'm sure many of you know exactly what I mean.
