Spit
- December 9, 2010
- Columbus Ohio
- 2002 XL
My daughter's 2002 has had some very weird electrical issues over the last few years. The most recent is with the power mirrors. They are not working and I started checking fuses. Looking at the owners manual it was hard to determine which fuse I should check...so I assumed it was fuse 26 a 7.5 volt in drivers side fuse box. I pulled it and the fuse was fine put it back in and mirrors still did not work. Just in case I had pulled the wrong fuse for giggles I pulled 27 also a 7.5 volt fuse it to was fine,,,but lo and behold the mirrors worked with 27 pulled out. I put it back in and they stop working.
I know..leave 27 out right? well you can't shift out of park if 27 isn't installed. Book says i27 controls the brake interlock circuit
I have not checked the wires thru the door which I assume is a likely cause.. but is this weird or what? Anybody ever have a similar situation or have any other ideas of what I can look at?
Spit
Spit
