2002 Explorer with 4x4 issues. | Ford Explorer Forums
run415
2002 Ford Explorer
2002 Ford Explore 4x4. The front end was feeling like it was locking up on dry pavement. The 4x4 dashlight was flashing. Took it to Ford dealer and they said it was throwing a code for bad wheel sensor. After they told us that, the 4x4 stopped working all together. I replaced the wheel bearings/sensors and now the light on the low 4x4 Button is on. Not the one on the dash. Can't get it to go off. Can't get the 4x4 to work either. Any suggestions? Big snow coming at us this weekend and I have no 4x4.
Thanks
Thanks
Welcome to the forum! :salute:
Here are some threads for you to check out:
http://www.explorerforum.com/forums/showthread.php?t=271868
http://www.explorerforum.com/forums/showthread.php?t=235287
This should get you started in the right direction. If you can't find what your looking for then you might try searching or posting in the 2002-2005 Section.
Good luck with the fix and keep us posted! :biggthump
welcome
