2002 Ford Explored, Stalled then will not start | Ford Explorer Forums
geodent
Seymour TN
2002 Ford Explorer
Hi I am geodent. I have a 2002 ford explorer. My problem is that it quite running in the middle of the road. when I tried to restart it there was nothing, no clicking just nothing. I have checked the battery and it is charged. Also replaced the ignition switch which did not fix it. What should I do next?
Not sure if its the starter this would not cause it to die in the middle of the street. But a bad fuel pump would do this. does the motor crank at all?
Did you check the starter? .....Yes Checked the starter,it is good.
Not sure if its the starter this would not cause it to die in the middle of the street. But a bad fuel pump would do this. does the motor crank at all?..... Will not crank ovver at all, dose not even try to crank,no clicking etc. Fuel pump is working...
geodent
This is a tough one. I will look through my alldata tonight to see if I can come up with something. I wonder if your ecm is getting power to run the car. I will get back to you.
Tom
