IndianaKenny
- July 31, 2014
- Lafayette, Indiana
- 2002 & 2004 Explorer
A couple of days ago I swapped an engine in my 2003.
Everything went as expected, except the engine wont start.
I've got good compression everywhere, fuel pressure at the fuel rail, a noid light tells me the injectors are cycling, but the darn thing won't run.
I bought the truck knowing it had a broken timing chain, and expected it to run, after the engine was swapped. No luck.
Yes, I used the original injectors and fuel rail, camshaft, knock, and crankshaft sensors.
I spent today swapping other sensors around, to no avail. I also went through each and every vacuum line and rubber boot, to see if there was a crack or leak, again, to no avail.
The only odd thing I see is that my spark tester flickers ALOT more than I expected, on each cylinder. Again, crank and cam sensors swapped, but no difference. I'm gonna put another coil pack on, but this will be number 3, (Thankfully I have a box of old parts from the last swap).
Any suggestions?
Thanks!!!
The
Any suggestions?
Thanks!!!
The
