ktmom
- July 21, 2013
- Central Florida
- 2003 4.6L Eddie Bauer 2wd
I just finished replacing the timing chains (tensioner failed on right side). Everything is together. Starts and runs fine. BUT... both valve covers are leaking at the rear, the left side badly. I torqued to 89 in/lbs. Started from the center and worked out alternating front to rear.
Did I do this wrong? I cleaned but did not replace the gaskets (and put gasket maker on the timing cover to block joint). Should I have replaced them?
