2003 Air Bag Light Flashing 33 | Ford Explorer Forums
2003blueexplorer
2003 Explorer
I looked on this site and found out I had a problem with my drivers seat pretentioner. I replaced it with a new kit from Ford 3l2z-7861203-aae. It included everything. I still have the 33. So I swapped driver side harness with passenger side harness no luck. Not sure where to look next.
Did you look at the prongs in the connector in the truck? Have heard they wear in and don't complete the circuit because they no longer are bent out... Would be a free fix...know I've read it has happened to others...
Lesson Learned
I finally got some time to look at the harness. I must have pulled on the wires as i was unhooking the connector and i pulled on of them out. A couple of connectors and the Code 33 was gone.
