fleetwoodd
- October 8, 2012
My 2003 Explorer has a front passenger side window issue that I could use some advice on how to fix.
The window will only go down using the front passenger side switch. However, it will not go back up unless, the battery is disconnected and then reconnected. Then the switch will work and the window will roll up fine.
The driver's switch for the passenger side window will only roll the window back up once the battery has been disconnected and then reconnected. It will not roll the window down.
Any ideas on what might be causing this? Thanks!
