2003 Explorer rough RPM deceleration | Ford Explorer Forums
natelunt
Meridian
2003 Explorer, V8
My ford explorer started stalling out at idle so I replaced the IAC which fixed the idle situation, but now my engine does not decelerate smoothly. When slowing down the engine hangs up at about 2000 RPM for a bit then abruptly drops down to normal idle speeds. This causes a bit of a jolting slow down and stop. Any help would be appreciated. My local mechanic is stumped and he has been working on various solutions for a week but nothing has helped. The situation does seem to get better after warm up.
Do you have a check engine light on? if so get the codes
No check engine light.
did you happen to check your throttle cable or throttle body (i assume you don't have throttle by wire) setup.
did you reset the computer after iac was installed, though it may be the egr
Did you install a Motorcraft IAC? I had (what sounds like) the same problem on my truck. The fix was replacing the new BWD brand IAC with a new Motorcraft IAC. It hurt my wallet because it ended up at a dealer to get the problem fixed.
cj1972 is right about about the motorcraft parts
What's the right way to reset the computer? I disconnected my battery for a few hours but that didn't help. I did use the standard IAC from oreilys. I replaced the first one with another new one, but the same brand, because it was originally much worse. The new one helped but its still not completely better. Maybe I should try the other brand.
you may want to try and drive for 40 or 50 miles to see if it will throw a code ,this will put you in a better direction as to the real issue is, instead of just throwing parts at it...have you gone threw the vacume hoses
Take the IAC and shine a light into it. If you see light coming through it, I would really consider buying a Motorcraft one. (The service writer at the dealer said the tech did this to determine that my [new BWD] IAC was bad.) I hope that helps.
Thank you for everyone's advice. I replaced the IAC with the motorcraft one and it immediately started running right. Best Regards.
I'm glad to see that it's running right. I know how frustrating and expensive it was when my '02 F150 had the same problem. It's upsetting when a new part doesn't work or doesn't work correctly. I went without my truck for a few weeks so I understand what you had to deal with.
