jstoughster
- February 25, 2014
- Tucson Arizona
- 2003 Ford Ranger
Hello,
I have read many of the treads on the forum about ABS engaging at low speeds and decided to change my front left ABS Speed sensor as the truck would pull right when coming to a stop and sensor would engage. After replacing the sensor the problem was not fixed. I went in to auto shop and talked through the problem and it was suggested that the issue is the ABS Module. Appears this is a hard part to track down and i assume it will be expensive once i find it.
My question is, does anyone have other ideas as to what is going on? Should I be trying other ideas before going down the path of a new ABS Module?
Note: When replacing the new ABS Speed Sensor it did drop onto the garage floor as I was getting ready to work on it. Assuming this part is probably sensitive... is it possible I damaged it?
Any thoughts/ideas are welcomed!
