2003 Narrow brake rotor wear pattern | Ford Explorer Forums
mitch28
Burlington,MA
'03 XLT
Hi All-
I have a 2003 XLT with about 17k miles on it. It has never had any brake work done to it. The wear pattern (pad contact area) is very small. I've looked at other Explorers and they had a much larger contact (wear) area. On my truck the front rotors have about 1.25", and the rears 7/8". This seems really small, so much so as to impact stopping power/distance. Is this a factory defect? Both fronts are the same, as well as the rears. Were there any TSB's concerning this issue? Thanks in advance for your help.
Mitch
I hope someone has an answer, I have this on the rears also. Fronts are good.
I have taken them apart and wear on pads looks even.
Mine is a 2002.
Both sides are even but not a full wear on the entire rotor.
I have the same issue from the rears. It stops fine so I haven't fooled with it
