2003 sport trac towing | Ford Explorer Forums
ramonf32
Leechburg PA
2003 sport trac 4x4
I have a 2003 sport trac 4x4 with manual transmission with 3.73 None Slip axle. Can I tow a 2100 pound tent trailer?
Should be no problem if you are up to date on your maintenance and have a hitch.
This trailer has brakes. I noticed that under my dash close to the ebrake lever there is a wire harness plug. Is this for the trailer brake controller?
Yes as long as you have atleast a class III frame mounted hitch, some say you can use the bumper hitch but I wouldn't (personal preference).
If you're talking about the rectangular pigtail at the bottom of the dash under the steering column that's the OBD II connection.
That's what that is. :) I guess I'll have to get the trailer brake controller installed also
