94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
You can buy a set of boots and springs from Rock Auto for around $35. I would go this route. Motorcraft boots do not come with the spings. Denso, NKG or AC Delco would be a brand I works buy and they are reasonably priced and come with the springs. Do the best you can to get the grit from the wells BEFORE you remove the spark plugs. You don't want this material getting into yhe combustion chamber.Thanks Eddie. What a pain in the butt scooping coolant and sand out of the spark plug wells without a proper air compressor is! Any suggestions for what cleaner to use on the coils?
2004 FORD EXPLORER 4.6L V8 Spark Plug / Ignition Coil Boot | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.
www.rockauto.com
