proradvlx
- March 24, 2011
- Indianapolis, IN
- 2004 XLT AWD
? Has anyone had any success in removing and installing the rear upper ball joint? I have a press kit, but I cannot find any combination of the spacers that work. It seems there is just nothing on the bottom side of the ball joint to press against. Or, just replace the entire control arm, with a new ball joint in place. Have seen new control arms from $70-$100, so not as inexpensive as just doing the ball joint...... but is that the way Ford designed it, just replace the entire control arm? Thanks !!!
