balboa850
- November 5, 2023
- Tacoma, WA
- 2005 XLS
Just removed rear wheel hub to remove 2 sheared off bolts. I used the pickle fork to remove the upper ball joint, destroying the rubber gasket.
So, what I've learned is that I can't just replace the ball joint because I have 16" wheels so I need a whole new control arm.
Can I get away with just sticking the old ball joint in and been done?
How bad of a drive will I have?
Thanks.
Edit: for some reason I cannot reply to any comments using the reply or new post buttons. Anyhow, I bought a ball joint and will try and press out the old one before I buy a new control arm. I read on this forum somewhere about 16" tires causing issues and when looking at BJ's on Autozone, etc. it specifies not for 16" tires?
Thanks.
