My1scobra
- February 10, 2018
- Lutz, Fl
- 2004 Explorer XLT Black
I have a 2004 XLT explorer and the front passenger side, and rear windows will not go down. The only wire I found broken was a very thin Red/Black wire. I put in a new set of switches and it worked then stopped and that is when I noticed the broken wire. Putting 12V directly to it does not fix the issue and I can't find a good diagram of the window wiring. If any one knows of a site I can go to and look up what the red/black wire is used for it would be helpful. Tried pulling out the wring harness and it appears to be real short and will not come out. Trying to figure out if a different wire can be used. Thanks
