jjmich83
- November 1, 2016
- 2004 ford explorer
I've read multiple threads on this issue and have tried just about every thing I could. I recently replaced the rear diff in my explorer and the rear abs sensor is not reading. I've replaced the sensor, when I read out the wires from the abs module to the rear diff I get nothing. I searched for any broken wires or lose connectors and cant find anything. I cut in to the wires on the driver side and read out from there to the diff and got a good reading, and from the there to the abs module and got a good reading, but when I read from the module to the sensor I get nothing. The diff I installed I pulled off of a 2005 model which did not have the sensor installed on the diff, the sensors were installed on the wheels. Not sure if that could be the problem or not, this diff had a plug installed where the sensor goes. if anyone out there can give me some insight on this issue that would be awesome. This issue is causing the 4x4 auto to kick on.
